‎2021-05-06
10:01 PM
‎2023-05-23
04:04 PM
Rubia Torres
‎2021-05-07 02:30 AM
‎2021-05-07 03:10 AM
‎2021-05-11 08:13 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
‎2022-01-19 12:30 PM - edited ‎2022-01-19 12:30 PM
Hello.
I have seen a similar problem with Archicad 25 build 4013 INT FULL. I am wondering if this is a bug that has been checked before.
For instace, when the handrail ends at 300mm away from the last step in elevation, the floor plan says 333mm which is wrong.
Seemingly if the full return is chosen for the end and it is placed in slope, the presentation in floor plan goes wrong.
‎2022-01-27 04:34 PM
Dear Hiro,
Thank you very much for the report and I am very sorry for the issue!
Based on the screenshots and description, it looks very similar to the defect mentioned above. I could confirm that it still happens in AC25 Update 2, so I opened a case in our support system for further investigation. As soon as I have an answer, I will let you know!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
