2026-05-19 03:35 PM
I have pulled a balustrade from a previous project and want to change all the elements surfaces, i have been into every element to try and change this and believe I have done them all but i still see the old surface visible, also how can you change the baluster element to 45 degrees please.
2026-05-19
03:41 PM
- last edited
a month ago
To change the surfaces you have to go into every element into Component settings -> 3D representation and surface.
To rotate them:
2026-05-19 04:11 PM
Balusters can be rotated using the settings in the Baluster component settings> Style and Dimensions.
You can select their building materials and override their surface as well (Baluster component settings > 3D representation).
Review all the baluster types for segment and nodes to ensure they meet your expectations.
2026-05-19 04:26 PM
Thank you i have changed all those settings - it seems there is multiple balusters and i cant delete them.
2026-05-19 04:32 PM - edited 2026-05-19 04:36 PM
Click on the baluster you want in the top diagram so that it turns green, and then click on the “-” symbol to delete it.
Watch the attached video file.
