Barrel Vault SEO-no go
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2009-05-04
10:42 PM
‎2023-05-25
04:34 PM
Rubia Torres
Any comments?
- Labels:
Solid Element Operations
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-05-05 02:21 AM
What you are missing is the intersection of the two barrel vaults. I made two sets of intersecting barrel vaults. The first pair I SEOd as you did. The second pair I SEOd but used the Intersect operation type. The latter fits in the first pair.
HTH
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-05-05 07:30 AM
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-05-05 07:46 AM
Two intersecting walls of barrel shape.. Create a second barrel profile that is the NEGATIVE space of the original barrel. Then use BARREL2 to cut out both the barrel 1's...
Be sure to homogenize materials..
Visual Frontiers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-05-05 07:55 AM
vfrontiers wrote:If I remember well , I was able to do that but the profile was half vault not full , so its like 4 walls . not next to AC to check .
I am not sure why you're SEO'ing at all? If you make them WALLS with the complex profile and set the "origin" at the center of the vault, wouldn't they clean up naturally?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-05-05 08:19 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-05-05 08:28 AM
It reminded me of the original Indiana Jones. The scene in the Cairo Markets where all kinds of weapons e.g. knives,swords, ropes are being used and finally Indiana just draws his gun and shoots the guy.
But, looking through the US library, I don't see a cross vault by any name. Is it indigenous to Western Australia?
Thanks
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-05-05 09:35 AM
Erika wrote:I thought it came with the standard library (which may be a bit different to other country releases).
Thanks
But I couldn't find it there.
It doesn't even seem to be in our Australian Essential library which was specifically put together for Aussie users.
It is actually called "Cross Vaults 12" and is very similar to the other Basic Shapes (or primitive shapes) in the library (cones, tubes, etc).
I did find something in the ACE library which was an amalgamation of all the various international libraries.
But that was only version 11 and it was in an LCF file that can't be extracted.
So it must be from an Archicad library somewhere.
The object I have is definitely version 12 and is not in a container file so it wasn't the ACE library.
I'll keep trying to track down where it came from and will post back.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-05-05 09:50 AM
There is a section in the library called "Vaults 12".
I'm not sure if this is in the other national libraries.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-05-05 04:26 PM
Sure would like to find the cross vault object. I wonder if it would work with two barrel vaults of different diameter, which is what I have.
