2021-10-29 05:25 PM
Beam Cross-Hairs seem to not be working correctly in V25.
Has something changed?
Solved! Go to Solution.
2021-10-29 09:20 PM
Check your MVO settings. There is a global control for cross-hairs (Symbol).
2021-10-29 05:40 PM
Can you show a comparison with what you used to see? I thought cross hairs were for columns and axis lines on beams?
2021-10-29 06:02 PM
Sorry - I meant columns.
However i wish beams had this feature.
When i place a new rectangular column with no segments in V25 I can go through the crosshair choices and I see the choice displayed in the settings, but when i view the column in plan there are no crosshairs or I only see part of the crosshair as if the fill (or whatever it is that creates the crosshair) is misaligned. I use this feature all the time, but this may be the first time I have tried it in V25.
2021-10-29 07:20 PM
Ok - New information.
If I open a new instance of V25 and place a column then the cross-hair works as expected. If i copy the column and place it into the project i am working on the cross-hairs are not there. This is not a pen table problem.
2021-10-29 09:20 PM
2021-10-29 09:46 PM
Dang - I forgot completely about that - Thanks!!!!
