gdford
Beam Cross-hair
Beam Cross-Hairs seem to not be working correctly in V25.
Has something changed?
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
1 Solution
DGSketcher
Legend
Check your MVO settings. There is a global control for cross-hairs (Symbol).
Go to post
5 Replies 5
DGSketcher
Legend
Can you show a comparison with what you used to see? I thought cross hairs were for columns and axis lines on beams?
gdford
Sorry - I meant columns.
However i wish beams had this feature.
When i place a new rectangular column with no segments in V25 I can go through the crosshair choices and I see the choice displayed in the settings, but when i view the column in plan there are no crosshairs or I only see part of the crosshair as if the fill (or whatever it is that creates the crosshair) is misaligned. I use this feature all the time, but this may be the first time I have tried it in V25.
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
gdford
Ok - New information.
If I open a new instance of V25 and place a column then the cross-hair works as expected. If i copy the column and place it into the project i am working on the cross-hairs are not there. This is not a pen table problem.
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
DGSketcher
Legend
gdford
Dang - I forgot completely about that - Thanks!!!!
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
