4hotshoes
Beam Intersections Not Cleaning up
I am using the Beam Tool to make footings and the intersections will not clean up. They are all at the same elevation and the setting is on to clean them.  They all are flat and level. I don't usually see this problem. All of the endpoints are connected. Any Ideas on how to make them join?
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
6 Replies 6
I am assuming they are all in the same layer.
Is the Intersection Priority Number for that layer set to 0 (zero)?
They won't trim if it is.
Rico
Did you accidentally deactivate this option:
iMac 27" 5K • macOS 10.15.7 Catalina • 40GB RAM | ArchiCAD 24 5004 FRA
Ryzen Threadripper 3970X • Windows 10 • 64GB RAM | ArchiCAD 24 Solo UKI
Lingwisyer
Guru
As in they have no depth? Unless they have changed something, things do not connect when they have a thickness of ZERO... Can you make then 0.01 instead?
Ling.
4hotshoes
The layer they are on have the intersection priority set to "1" not "0"
Todd Oeftger
4hotshoes
Ye that was the first thing I checked and said so in my first post. "intersection clean up" is on
Todd Oeftger
4hotshoes
No. They are all set to 12" thickness, not zero.
Todd Oeftger
