Beam section line colour
Hi all,
can anyone tell me how to change the beam section line colour? Why is that option greyed out?
Cheers in advance
10 REPLIES 10
Is the Apply Structure's Setting checkbox checked?
Hi Laszlo,
Is this in the Beam settings dialog box under Plan and Section? There is nothing there for me to check.
This is what I meant.
This option appears if the Beam is a complex structure.
Hi Laszlo,
the beam is just a simple rectangular one. There is no option to check in the Settings dialogue. Does this mean that this is an option only for conplicated beams?
Yes, this option applies to Complex Beams.
So,
in my case what is the solution? Change all beams to complex beams?
Can't you use this dialog box? It works for me.
Simple regular beams sections...
cartann
as you can see in my case the two menu options are greyed out
well, just make sure you are using the right tool, or restart AC.
That kind of thing happen when I'm doing something slightly wrong.
Like not selecting the right options in section view, or something like that, or maybe a glitch in AC.
