ā2021-08-25
10:15 PM
ā2023-05-24
06:59 PM
Rubia Torres
Solved! Go to Solution.
ā2021-08-25 10:53 PM
ā2021-08-26 12:13 AM
ā2021-08-27 08:42 AM
ā2021-09-03 09:39 PM
Have you tried using a rail tool as the road driveway?
(Using a custom profile rail defined in the Complex Profile Manager with your composite section, and then magic wand-ed onto your site mesh on a pre-defined path (polyline) with the gravity-to-mesh turned on).
Pros : very easily adjustable and controllable using the rail nodes in 3D and the Complex profile manager to adjust the profile, width, curbs, etc)
Looks very convincing in 3D depending on how much resolution you want.
Cons - doesn't display correctly in 2D plan window and might need a workaround of drawing the road path correctly in 2D using linework separate from the rail object (Graphisoft/Rail tool issue)
