Kaj_AL
Best way to model curved curtain wall
Hello!
We're working on a cylindrical building with diffent radii on the different stories.
We're now at the stage where we want to model the facade in more detail, but we're a bit stumped on the best way to do this.
The image below is made with walls and columns. It has a nice appearance, but it's quite labor-intense. The curtain wall tool seems like the way to do it, but we can't get the corners to look nice. If we would have the exact same angle between panels all over the place we could model a profile, but since the radius is different we would get so many different frame parts it would be too confusing.
Any ideas on how to do this?
Thank you!
/Kaj
Archicad 24-27 SWE
Dell Precision 5560, Windows 11 Pro
11th Gen Intel(R) Core(TM) i9-11950H @ 2.60GHz 2.61 GHz
Setup info provided by author
4 Replies 4
Kamelite
Not sure I understand the problem, a curtain wall can be curved....
Or was that not the issue?
.Kamelite
Windows 10, Archicad 28
Kaj_AL
Hi!
Sorry, the question was unclear.
Maybe it's my lack of understanding of the curtain walls, but my joints look like this:
Archicad 24-27 SWE
Charlie64
Hi
I don't think the problem is in joints, but rather in the pannels. I tested it and the joints follow the curved line nicely, however the pannels just "connect the dots" - joints - in a straight line. I believe that the effect you're going for is how to bend the pannels. I don't know how to do it or if it's even possible to do.
Good luck!
cocoloco
I’m just here to say that with Archicad, is very behind on curves, flutes, or anything angular, there’s never an easy solution. They rarely listen to user feedback or requests, so it’s unlikely that will ever change. If there is fix to this, prepare that it’s something ridiculous tool to do it through - like railway, mash etc. 🤣
MacBook Pro, Sonoma: 2.6 GHz 6-Core Intel Core i7, Intel 16GB mem,
Archicad Solo 26 and 27 (in testing mode)
