Best way to put a footpath on a terrain?
We have a contoured mesh for the front garden of a residential project, and we want to put some curving paths across the terrain.
Does anyone have any suggestions for the best way to do this?
Thanks!
3 Replies 3
Try this link for Peter Devlins PDF explaining ways to do this.
http://archicad-talk.graphisoft.com/viewtopic.php?t=7127
HTH
Nuge
use a mesh
AC27 i9 14900KF / 128G ram / GTX 5090 / D5 Render
If the path is meant to be stones set in the earth rather than
a continuous path of some other material (like a roadway),
I have often used little thin roofs laid in the surface of the mesh
to simulate a stone path. The roofs can be tilted to lay
on the mesh surface correctly.
Thank you,
Peter Devlin
