rengarch
Auto Text in Archicad
If I remember correctly in version 8.0, you use to be able to put an auto text such as <PmAShNo>in Archicad and when imported into Plotmaker would insert the sheet number. Is that still possible in version 9.0?
Rita
Rita MF Eng, AIA
iMac 27" 3.5 GHz Intel Core i7
NVIDIA GeForce GTX 780M 4096MB
MAC OSX 10.11.6
Archicad 20
__archiben
of course! <PmAShNo> is written into a couple of the section/elevation/detail markers as a part of the GDL object. you don't place it as text on the floor plan and hope that plotmaker knows what you're on about . . .
take a look at the various parameter options in sect/elev/detail marker objects. as far as scripting your own marker objects to take advantage of this, i can't help: i'm GDL hopeless . . .
HTH
~/archiben
b e n _ f r o s t
TomWaltz
That's not entirely true. "PMAshNo" is simply filler text that the markers put in to tell you that Plotmaker is going to fill them in automatically. The text could say anything. For example, our custom markers say <Drawing> and <Sheet>.
The marker object does all the work internally.
Tom Waltz
