2009-11-13 10:01 AM - last edited on 2023-05-25 05:48 PM by Rubia Torres
2009-11-13 01:19 PM
2009-11-25 01:28 PM
Select the Slab and check the Cover Fill checkbox in the Info Box or Settings Dialog. Then you can set the type, pen etc. of the Cover Fill.I did this, but after that, i can only set a specific color for my color fill, not an image.
Bitmap is a global setting and can be toggled (ON/OFF) by the View\On-Screen View Options\Vectorial Hatching menu item.Is that the solution of the problem? After turning that option ON, will that result in opening some other settings, that will enable me to add an image as a slab cover fill?
2009-11-25 03:50 PM
2009-11-25 07:33 PM
2009-11-25 07:52 PM
2009-11-26 09:13 AM
