Box Windows
Ashleigh2
I am pretty new to using Archicad so a few things are stumping me along the way.  I am trying to create a box window that you can sit in that has a set depth of 60cm.  I would like 20cm to sit internally and the remainder to jut out of the external wall.  I have attached an image of what I have done so far.  Can anyone please help to advise how I extend beyond the external wall (rather than having the whole seating area inside)?
Thanks!
2 ACCEPTED SOLUTIONS
Ricardo Lopez
Hi @Ashleigh2
May be you could try playing around with: Bay and Bow Windows 27> Square Bay Window 27
Also you could build the "box" using walls and slabs and a Basic Window instead.
Even an oversized frame with a negative revel could work. It depends on the building system and the detail you need.
Regards.
M. Arch. Ricardo López
AC17-28 SPA+INT | Windows 11 | MSI CreatorPro M16 HX C14VJG, 64GB, Nvidia Quadro RTX 2000 Ada Generation
Botonis
Mentor
This is easy with a Curtain wall.
Probably with more options and details than
the bay windows. It depends....
Botonis Botonakis
Civil Engineer, Enviromental Design MSc., BIM Manager for BS ArhitectsVR
Company or personal website
Archicad 27. Windows 11. Intel Xeon 2699x2,64 GB RAM, Nvidia 3080Ti. 2 Monitors.
Ricardo Lopez
Hi @Ashleigh2
Regards.
Take a look at Library Part Maker:
https://community.graphisoft.com/t5/Libraries-objects/Library-Part-Maker-Now-in-All-Localized-Archic...
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Botonis
Mentor
Botonis Botonakis
