Break morph union
Can a union of morph elements be broken afterwards?
If yes, how is it done?
Thank you!
1 Solution
No, because the geometry of the Morph is modified and the two or more unified Morph elements will become a single Morph element.
If you cannot do it with the Undo command, then you will not be able to undo it later either.
Go to post
1 Reply 1
