ā2013-04-09
08:58 PM
ā2023-05-23
04:31 PM
Rubia Torres
ā2013-04-11 02:03 AM
Hmooslechner wrote:No problem Heino, i wasn't expecting you to draw up a catenary straightaway! thanks
The matehmatics of an catenary (Kettenlinie?) is still too complicated for me ( i thoght about ropes - thats mathematicly just the other way round).
If it would be possible for me to calculate exact differences on a hyperbolic curve this would be nearest to it i think. But that takes till july and august, when i will have more Time.. Its just a hobby now..
ā2013-04-11 02:20 AM
ā2013-04-14 03:05 PM
Dwight wrote:This seems like a good solution as it wouldn't drain my resources. I've rendered the face of the arch. How do i apply the custom texture to the arch? I've looked around a bit but can't find a solution. Do I customise the GDL scripting? (I wouldn't be too comfortable doing that!)
You can also render the flat face of the arch and use that as your hi-res texture map. Use the 3D Align tool to make it fit.
ā2013-04-14 07:17 PM
ā2013-04-14 11:21 PM
ā2013-04-14 11:29 PM
ā2013-04-14 11:37 PM
ā2013-04-15 12:00 AM
ā2013-04-15 02:02 PM
trunmaster wrote:I think you want to Set Origin, not Set Direction.
Am I right in selecting the element then Design>Align 3D Texture>Set Direction? When I do this, it asks me to click on the main surface of the selected element, which I do and then nothing happens.
ā2013-04-15 08:04 PM
