Tom Krowka
CHANGE MULTIPLE OBJECTS TO COMMON LAYER
Did we lose a button on AC20. There used to be one right adjacent to the layer button on the object toolbar if one selected several objects that were on different layers. How can I change multiple selected objects to one common layer when they are on differing layers.
Thanks.
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
6 Replies 6
Aaron Bourgoin
During Beta 20 GSHQ said that after analyzing user keystrokes that "Edit Selection Set" was not often used. Still on the menu bar, but the chuckle is gone
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
Tom Krowka
#$##!!& I used it quite a bit.
[email protected]
www.walshkrowka.com
All I know is that very often I find my self having to select several elements in different layers and want to change them to the same layer and Archicad cannot do them all at once, and it should.
Eduardo Rolon
That is what the "Edit Selection Set" command has always done. It will let you edit the common parameters between different objects.
FWIW since I always used the shortcut (MacOS CMD+Opt+T) I never used the button so I don't miss it.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
And you can still add the button to a toolbar - it is just not in the info box any more to give a bit more space to the layer name.
Stress Co_
I added it to a custom toolbar.
Located it just above where it resided in the pre AC20 infobox.
Marc Corney, Architect
Red Canoe Architecture, P. A.
