CHANGE STOREY, NOT ITS PROJECT ZERO LEVEL
G'day fellow passionate users,
I'm confident there's an answer already out there but couldn't find it. Feel free to point me to it and delete this thread if so.
I use to be able to change the storey where a bunch of items belonged to without changing their physical height from Project Zero. I was doing so by changing storey in the settings window. Not sure which version this has changed, but now if I change the storey, the height from Project zero updates (+ or -) to the new storey selected.
Issue: I have a bunch of items, sometimes the same type (walls for examples), other times a mix of walls, slabs, morphs, etc.
Those need to change storey, but their position in relation to Project Zero is perfect and needs to stay.
How can I do that?!
Thank you in advance
Select what you want to change (plan or 3D).
Right mouse click and choose 'Relink Home Storey'.
Guardian Angel named Barry.
Cheers
