CHANGING COMMAND SHORTCUTS
while trying to modify some commands to better understood keys, I have found that the command modification file will not come up. Nothing happens when presses this button. Any ideas of how to get the command/shortcut file to appear?
Archicad 17
5 REPLIES 5
I believe it depends on what you have set as your default internet browser.
I have Windows Internet Explorer and that works fine.
I can't vouch for any others working or what is required for a MAC.
David Maudlin
Safari works on Mac.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I thought that was the issue also but no go. Obviously its modifying a file. any one know what file name that might be? Perhaps I can open it in notepad to do it.
ARchicad 17 ,windows
This is the path of the file that opens in Windows Explorer when I show the shortcuts.
C:\Users\barryk\AppData\Local\Temp\ShortcutLayout.htm
Barry
B right where you said,open just as it should in archicad, thanks
