COMPOSITE WALL WILL NO MITER
Eric Milberger
I created a new composite wall.
  1. When I try to miter two wall and join.  they do not - they miter to the core line but do not miter.
  2. When I tell it to create a curve it looks correct BUT
    1. There is a line where the curved wall starts and the straight wall begins
Eric Milberger, Architect | Master Planner
Eric Milberger
The problem is straddling 4 different cad packages and not being able to focus on one.
Found the answer -
Eric Milberger
Found the answer -
JKL
What is the name of that button?
Designer
Mac
Archicad 26
The command can also be found in the VIEW menu.
Barry
