Read more
Cameras not working
Hi all,
My cameras do not seem to be working. When I choose one in plan view, go to 3d, all that happens is that I get a horizon view. All cameras are set at 4400.
As far as I know, without cameras, I cannot photo render (just learning).
Any ideas?
Thanks,
Hayley
6 REPLIES 6
Hi Hayley,
Maybe this thread http://archicad-talk.graphisoft.com/viewtopic.php?p=167344&highlight=camera++window+model#167344
can help you.
Adrian Tudoreanu
David Maudlin
Hayley:
Also, you can right-click in the 3D Window and select "Show All in 3D" to make sure that the entire model is being shown, not just a part of it. You can also check the "Filter Elements in 3D" dialog box again to make sure the entire model is being generated.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Hi David,
Unfortunately, your solution did not work. However, one of my camers does seem to be working, in a manner. That is, it's cutting most of the view away. When I do a fit to window, everything disappears into the distance as a small dot.
I'll post a picture of th semi working 3d window.
Thanks again for your helo.
Hayley
David Maudlin
Hayley:
This looks like the bug described here:
Bugs/Model cut in 3D
HTH
David
David,
It's probably totally inappropriate to say this but...."If you were here, I'd kiss you".
Thank you so much for helping me - AGAIN!!
You are a superstar.
Regards,
Hayley
David Maudlin
Errr .... ahhhh ... a handshake will do.
Your welcome.
David
