Can I create and object?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2013-02-10
06:45 PM
ā2023-05-23
04:32 PM
Rubia Torres
Archicad 14
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2013-02-10 10:07 PM
Editing the original makes updates available to all placements.
This feature is meant for floor plan components like repeating suite layouts, so there's a complex set of linked external files to be managed, but the process can be applied to other assemblies.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2013-02-10 10:29 PM
I will give that a try.
Madison WI
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2013-02-19 08:51 PM
Gus wrote:If I understand your question correctly, all ArchiCAD objects work that way. All you need to do is edit the object (Ctrl+Shift+O ) and that object can be updated in all locations.
Using SketchUp one can make "components" then place those components throughout a model then every time you edit the component it changes in all the models. Is there a way to do this with Archicad? Can I create an object like this?
Archicad 14
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2013-02-19 09:43 PM
For instance, at any time a Component can be visually edited and/or made unique, affecting all the others [or not]. It is Child's play, like all of SketchUp. I've been called a shill on this forum before, just yesterday, in fact, but what a great program!
Attempting to use an Archicad Object as if it were a Component can be done, but only if you carefully maintain the original model [usually managed in a separate object-building layer, or a second copy of Archicad reserved for object making] since opening an Archicad Object only yields GDL code and not editable elements as does Component editing. The process here is not to open the original Object and attempt to edit its code [not trivial because of incomprehensible [!!!] code and possible fatal coding errors - besides, we aren't a typist, are we?], but rather to open the original object model, edit it and then replace the original Object.
This method is cumbersome and scary for a beginner, or anyone for that matter. GDL nightmares await ye who enter there.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2013-02-19 11:06 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2013-02-19 11:09 PM
Gus wrote:What kind of object did you have in mind?
Archicad 14
