‎2013-02-10
06:45 PM
‎2023-05-23
04:32 PM
Rubia Torres
‎2013-02-10 10:07 PM
‎2013-02-10 10:29 PM
‎2013-02-19 08:51 PM
Gus wrote:If I understand your question correctly, all ArchiCAD objects work that way. All you need to do is edit the object (Ctrl+Shift+O ) and that object can be updated in all locations.
Using SketchUp one can make "components" then place those components throughout a model then every time you edit the component it changes in all the models. Is there a way to do this with Archicad? Can I create an object like this?
Archicad 14
‎2013-02-19 09:43 PM
‎2013-02-19 11:06 PM
‎2013-02-19 11:09 PM
Gus wrote:What kind of object did you have in mind?
Archicad 14
