Jefferson
Can a .lck file be retrieved once the project was closed?
major dumb SH!_ move here.........I had a bunch of programs running and in closing them all down I accidentally closed a session of AC without saving, after oh, about 4 hours of intense & valuable work......unbelievable but sadly true.
I am wondering if the .lck files generated as what I have always assumed are autosave associated, once discarded or trashed, can be retrieved, [from where ever they go], and be used to get back to where I was...........maybe this should go on my wish list, but if someone knows where I can find it, assuming it's still "out there", and unless otherwise cautioned, I can give it a go at least.
Heading to the beach to walk the dog and berate myself outside........
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
12 Replies 12
Jefferson
"Maybe beer was Jeff's problem in the first place?
I'll just ...Hic!... shut down this ...Hic!... application ...Hic!
Was I ...Hic!... supposed to ...Hic!... press that ...Hic!... button? "
ouch mate! the self-destruct of this posting may be accelerated at the owner's discretion..........
jeff white
w3d design
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
Laughing because I have "Zombied-Out" in the same fashion, Jeff.
Hate to post here after the days have gone by and you have healed a bit from your self inflected wound.
I was curious (big problem) and looked at my C:\Documents and Settings\Jay\Graphisoft folder and found there to be 4 "ArchiCAutoSaveave Folders" Only the two most recent ArchiCAutoSaveave Folders had the additional ArchiCAD.TMP and @Lock.T files. The other two ArchiCAD AutoSave Folders may be from my previous version AC10.
Also in the Root Graphisoft floder I found 265 CrashDump-......dmp Files.
Are these files and folder ever purged? Can we? Should we?
Link
I'd delete them. I ~think~ the dump files are only needed if GS tech support al for them, and when's the last time that happened?;-)
GS used to (and hopefully will continue to) release ArchiCAD Cleaner applications that would clean all that old stuff out. Very effective cleaners if you can find them.
Link.
