Can a .lck file be retrieved once the project was closed?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2010-11-03 12:39 AM
I am wondering if the .lck files generated as what I have always assumed are autosave associated, once discarded or trashed, can be retrieved, [from where ever they go], and be used to get back to where I was...........maybe this should go on my wish list, but if someone knows where I can find it, assuming it's still "out there", and unless otherwise cautioned, I can give it a go at least.
Heading to the beach to walk the dog and berate myself outside........
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-03 01:51 AM
The .lck file is just a tiny lock file that detects you as being in the project, to prevent others from possibly opening it & overwriting your good work. You may have seen the 'This project is in use by 'Mr-I-Don't-Need-to-Save' @ His Computer'.... Open with Exclusive Access/Don't Open/ Open as Read-Only' Information warning? That lck file causes that warning to appear if you try and open the file twice or if someone else tries to open it at the same time. So the.lck file ain't gonna help you retrieve data.
If you effectively crashed out of ArchiCAD, there should be an autosave document stored on your machine. The actual path is set in your work environment profile under Company Standards Schemes> Data Safety> AutoSave Folder. Mine is set to C:\Users\Link\Graphisoft, so your may be similar. I HOPE that you have autosave turned on! There should be an @Global.T file in there somewhere which is an exact copy of your project as of the last autosave. It is a good idea to copy that file out to your desktop, just in case!
[There could be multiple autosave folders if you crashed out with multiple projects open]
In any case, ArchiCAD should prompt you to rescue that file once you start ArchiCAD again.
Cheers, Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-03 01:57 AM
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-03 02:29 AM
And yes autosave is set, every 15 seconds, however I oh-so-stupidly had reopened Archicad just before reading this post, sssooooooo, the autosave file is/was now only related to the last open AC file. Closing the just opened file emptied the autosave folder. Any chance I might have had is now gone fo good
This post will self-destruct in 12 hours so laugh it up while you have the chance and learn from my mistakes mates
w3d design
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-03 02:35 AM
So did you save or did you ignore the prompt?
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-03 02:42 AM
Unfortunately it's gone. You LOST all. When you closed AC it ERASED the entire folder named "ArchiCAD AutoSave Folder"...It contains a sub folder "@ODB_ObjectSetsxxxxxxxxxx and 3 files, one of this is your .lck file "@Global.T") . Now if you started AC again it will create an empty folder with that name in the same place.
Maybe some program for UDELETE FILES could restore that file (@Global.T), but you MUST USE IT BEFORE starting AC again!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-03 02:44 AM
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-03 02:45 AM
andro55 wrote:Way to make him feel better!!!
"...I accidentally closed a session of AC without saving..."
Remember Jeff, beer is always your friend...
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-03 03:31 AM
A few more posts here since I stepped out check on my new best "friends" in the refer. Not hitting "save" instead of AND hitting "don't save", [worse than
Time to go rebuild what was from memory, and indeed it
w3d design
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-11-03 03:44 AM
Link wrote:Maybe beer was Jeff's problem in the first place?
Remember Jeff, beer is always your friend...![]()
I'll just ...Hic!... shut down this ...Hic!... application ...Hic!
Was I ...Hic!... supposed to ...Hic!... press that ...Hic!... button?
All said jokingly of course.
