2010-11-03 12:39 AM
2010-11-03 01:51 AM
2010-11-03 01:57 AM
another Moderator
2010-11-03 02:29 AM
2010-11-03 02:35 AM
2010-11-03 02:42 AM
2010-11-03 02:44 AM
another Moderator
2010-11-03 02:45 AM
andro55 wrote:Way to make him feel better!!!
"...I accidentally closed a session of AC without saving..."
Unfortunately it's gone. You LOST all. When you closed AC it ERASED the entire folder named "ArchiCAD AutoSave Folder"...It contains a sub folder "@ODB_ObjectSetsxxxxxxxxxx and 3 files, one of this is your .lck file "@Global.T") . Now if you started AC again it will create an empty folder with that name in the same place.
Maybe some program for UDELETE FILES could restore that file (@Global.T), but you MUST USE IT BEFORE starting AC again!
2010-11-03 03:31 AM
2010-11-03 03:44 AM
Link wrote:Maybe beer was Jeff's problem in the first place?
Remember Jeff, beer is always your friend...![]()
