ā2009-03-27 11:08 PM
ā2009-03-27 11:18 PM
ā2009-03-28 04:56 PM
ā2009-03-28 05:16 PM
ā2009-03-28 07:20 PM
ā2009-03-28 09:54 PM
ā2009-03-28 11:01 PM
ā2009-03-28 11:02 PM
ā2009-03-28 11:03 PM
ā2009-03-29 02:54 PM
Jere wrote:I can see some logic behind not being able to delete mullions (vertical) on curved walls, the consequences are more obvious with small radii. Should the resulting panel chord (span) between the remaining mullions, or should it break where the mullion was removed? This same issue also exists for the upper and lower transom frames. Not so important (but an issue) in Jere's use, but a dilemma for a typical curtain wall system.
With this project, the radii are large (38' feet or so)[11.5m], but with smaller radii it would be very difficult as straightening it would remove many of the gridlines.
