Can't create stair on selection
I'm trying to create a custom stair (slope) using the shape shown in the picture. but i can't, and instead I get this message (also in image)
Any idea why? cant figure this out...
I created the lines using a normal line and an arc line.
Thank you in advance!
5 REPLIES 5
JLopes
take a look at the tutorial:
http://www.youtube.com/watch?v=cyPptuloN8k
|| JLopes ||
AC29 Port || Ryzen 9 5900x | RTX3080 | Win
Hi, thanks for the link!
It worked, but with the shape I have, I can only select stairs, and not slopes... Is it possible to create slope from selection?
Srinivas
Did you check this option?
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
Yup, but it wont let me choose that to begin with...
It looks like i cant make slopes unless everything is straight/perpendicular....
Use a mesh for this.
Draw mesh wot match your required outlines and then elevate the points to the required levels, if you require appearance of a slab in section use the roof tool to create sloping slabs.
