Can't make the contour lines in a terrain with the mesh tool
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2008-11-05 05:07 PM - last edited on 2023-05-25 05:09 PM by Rubia Torres
2008-11-05
05:07 PM
I'm working in modeling a site which is a steep terrain and irregular shape, and used the surveyor's dwg plan, I made an independent worksheet, I exploded it and ungroup it and set it as a trace reference, which I'm using it as a trace.
The problem is that after setting up the mesh and create it, i selected the mesh to start working with the contour lines but when I start doing this with the magic wand, it doesn't do anything, it doesn't create each of the contour lines, so I'm stuck with out been able to make my terrain.
Does anybody knows what might I have done wrong?
Thanks!
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-05 05:54 PM
2008-11-05
05:54 PM
I am pretty sure the magic wand will not work for this type of application if what you are trying to use it one is a trace reference. Try putting your surveyors plan on top of the mesh and not in a work sheet.
16" MacBook Pro M1 Max
Mac OS 12.2.1
ArchiCAD 25 Build 6005
Mac OS 12.2.1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-05 08:10 PM
2008-11-05
08:10 PM
rucailo wrote:This should work - I've done it many times. Are you doing the following:
- 1. Select the mesh
2. Click on the mesh tool
3. Space-click on a contour
Ralph Wessel BArch
Active Thread Ltd
Active Thread Ltd
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-05 11:27 PM
2008-11-05
11:27 PM
iv found it to work best if i stick a copy of the surveyors plan on my site plan/story.. creat the mesh then delete the survyors stuff
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-06 12:21 AM
2008-11-06
12:21 AM
Thank you, I just did that and it worked, thanks again
