2018-03-16 03:29 PM - last edited on 2023-05-24 08:23 AM by Rubia Torres
2018-03-18 05:35 PM
2018-03-20 03:43 PM
LaszloNagy wrote:Thanks for the reply!. It is very weird, Sometimes it works normally others curtain walls can't be selected at all on sections. I'll try the hotfix thing and try again.
Never came across this issue but I can suggest 2 things:
1. If it is true that you are using build 3003 of AC19, then you should definitely install the latest hotfix, it has many bugfixes.
2. Update your graphics card drivers, sometimes those drivers can cause stranger issues on your screen.
