Can't stretch 2D objects freely
Sakha
So, my Archicad can't stretch objects other than multiples of 50, but only for the project I'm working on; in new projects, it's no problem. How do I fix this?
2 ACCEPTED SOLUTIONS
CosminF
hi,
You may have accidentally enabled grid snapping (with Alt-S) ? Try seeing if you have something enabled here:
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
check the snap grid.
ā€ƒ
AC 28 INT 5200/WIN 11
CosminF
hi,
ā€ƒ
Sakha
thank you, this community is really good, bless you all šŸ‘
