Can you create custom profiles for the Interior Wizard add on?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2024-01-31 06:40 AM
Version: AC27
Hardware: Macbook M2
Hi Community,
I'm using the Wall Accessory option downloaded with the 'Goodies' add on.
It's a great tool but wondering if there is a way to use your own custom profiles for the Base, Chair and Crown Mouldings?
Thanks.
- Labels:
Complex Profiles
Goodies
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-01-31 07:25 AM
With the default object - no.
But the accessories are just GDL objects, so it could be possible to edit and allow it to use custom profiles.
I know that can be done as I have done it for my own cornice object that works as a slab accessory and I can use custom profiles.
There will be a little bit of work needed to amend the graphical interface to allow you to choose from a list of profiles.
So you will need to know what you are doing in GDL.
That might be an interesting exercise to tackle if anyone has the time.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-01-31 03:28 PM
I have this built into my wall accessories. For door and window casing as well.
I have not adapted it for the interior finish wizard as I don't use it currently but most of the data is the same so probably would be rather easy to do.
