Cannot rotate beams to desired position
Pardon my sarcasm, but is it ridiculous to want an upside down t-section or to rotate a steel angle beyond 90 degrees relative to its long axis? If any one else has experienced this problem and found a solution please let me know.
Thanks,
Matt
11 Replies 11
So far, so good. Lets hope my file doesn't develop problems later. Although, that hasn't been an issue since going to mac systems.
Matt
You can also change the flange to be on the bottom.
Brian
