Cannot rotate beams to desired position
Pardon my sarcasm, but is it ridiculous to want an upside down t-section or to rotate a steel angle beyond 90 degrees relative to its long axis? If any one else has experienced this problem and found a solution please let me know.
Thanks,
Matt
11 REPLIES 11
TomWaltz
Not ridiculous at all to want, very ridiculous that the object does not allow it.... the only way I see to make that without editing the GDL code would be to make the shape you want with a Profiled Beam instead of an object, but that's not really idea either because it does not hold the beam depth if you slope it.
Tom Waltz
Very well, but I desire a dimension other than the one that is predefined for any of the t-shaped profile beams. i.e., that used in a t-bar ceiling. After my experience with AC10, I am afraid that my product support will tell me to wait for AC12 for the desired functions.
TomWaltz
by "dimension", do you mean you need a custom size? I thought the beam objects allowed you to make your own sizes.
Tom Waltz
for clarification: Are you refering to metal beams within the Archicad Objects Library or those made with the Beam tool?
Matt
TomWaltz
Matt
Metal beam objects in the Object Tool
Tom Waltz
OK. The metal beam object allows for a custom size, but is limited to +or- 90 degrees in the rotation parameter, preventing a t section, for example, from being turned upside down. I can always draw the needed profile in 2-d, but that seems to go against the reason I use Archicad to begin with.
Any direction?
Matt
TomWaltz
It's a little annoying, but there are a couple workarounds I can think of:
1) place a W-beam then use an SEO to cut off the top flange
2) place 2 L-angles back to back
Tom Waltz
I was able to find the limits in the GDL script and change it to allow -180 to 180 degrees and bam, freedom to design freely. Now I just have to use my custom object rather than the Archicad Library object.
I have appreciated your help on the issue. Hopefully Graphisoft will catch on to these sorts of annoyances that hinder the design process.
Thanks,
Matt
TomWaltz
I was tempted to recommend that, but was afraid of what other weird effects it might have. Sometimes weird limitations were due to some other programming issue.
Tom Waltz
