2007-07-20
10:40 PM
- last edited on
2023-05-26
12:52 PM
by
Rubia Torres
another Moderator
2007-07-20 10:46 PM
2007-07-20 11:15 PM
another Moderator
2007-07-21 05:30 AM
ejrolon wrote:Eduardo, I reported this during beta and have had one more
Ok did a new and reset and it worked fine./..... If anybody want to test it please PM and I will send the file.
2007-07-21 05:48 AM
another Moderator
2007-07-21 07:10 PM
ejrolon wrote:No need for a file - the 'new' from the default US template demonstrates this bug every time, and your workaround of selecting complex and then back to square or circular works. Good work. Since it is 100% reproducible now, I've reported it again with a link to this thread and a mention of Rod's beta report.
Ok did a new and reset and it worked fine. For the one that it is not working you have to select the "complex profile" and switch back and then you will be able to select the lineweight and linetype. The problem might be the migrated template that I used to start the project.
I would place the file for testing but it does not reduce to the minimum allowed even with only one column in the file. If anybody want to test it please PM and I will send the file.
2007-07-22 03:25 AM
Karl wrote:Thanks Karl. Tested Eduardo's file yesterday.
/.............. and your workaround of selecting complex and then back to square or circular works.
2007-07-23 12:41 AM
another Moderator
