ā2014-02-11
09:03 AM
ā2023-05-23
02:32 PM
Rubia Torres
[/img]ā2014-02-11 09:24 AM
ā2014-02-11 09:38 AM
sboydturner wrote:Thanks for your reply!
Joe,
turn of cover fill to the roof and you should be able to see the walls, I usually have a new storey for the roof and have it display dashed the storey below.
Regards,
Scott
ā2014-02-11 09:53 AM
ā2014-02-11 09:56 AM
schagemann wrote:Thanks! That worked!
Select the roof, open the Roof Selection Settings (CMD + S) then under the 'Floor Plan and Section' section choose to disable cover fills.
Arguably, however you should have your roof on a separate Story - you might find the following tutorials useful⦠http://goo.gl/58ngz5
