Cant create an Oval Staircase in AC21
Hi Guys,
Anyone know how to create an oval staircase? Ive tried everything including the magic wand, any tips?
Thanks,
Cain
https://imgur.com/a/kBrKY1w
10 Replies 10
Looking at this again, the risers of your oval stair all emanate from one central point.
So create a large circular stair and then adjust the stair boundaries (not the baseline - leave that circular) and you may be able to get what you want.
Add nodes to the arc and adjust the edges to match the curve of your oval.
I just had a go tracing over your image but I can't get the top point of the stair to pull down enough to match your oval.
Close but not quite.
It seems there is a limit to how yo can adjust the boundary - which I am a little surprised at.
Yours may work as you have a more accurate drawing rather than an image I copies from the forum.
An alternative would be to create a slab with an oval shaped hole and the Solid Element Operate this with the stair to cut the shape away.
