ā2018-10-10 05:47 AM
Solved! Go to Solution.
ā2018-10-10 07:48 AM
ā2018-10-10 08:42 AM
ā2019-01-14 05:57 AM
ā2019-08-11 11:35 PM
ā2019-08-14 05:55 PM
ā2019-08-15 01:40 AM
whatwaitnow wrote:Is it mandatory that you use the Stair Tool? Otherwise, any stair can be modeled with ArchiCAD exactly how you need it to be. You do not need to use any other programs.
Update:
AC21 cannot do the elliptical shape i required, neither could Revit, ended up using Autocad and Sketchup.
ā2019-08-15 11:18 AM
Hmooslechner wrote:I could do an oval shape, just not the specific oval shape required for compliance and ascetics.
Archicad makes some silly things at stringers by complex stairs. But there are other things that can be done about this: Use Profiles and Morphs. (Also maybe helpful - the use of the railingtool with the profilemanager.)
a try to get it working:
ā2019-08-15 11:19 AM
Steve wrote:Yeah much preferred to use the stair tool, so i could make small changes, ie, risers, widths without redoing the whole structure.
Update:
ā2019-08-15 05:56 PM
