Cant use Goodies Suite
walefisch
Beginner
I cant use see the goodies options under design extras after installing them and also installing the latest archicad version again.
Have you tried installing the Goodies again and then the latest update again but do not launch Archicad in between the installations?
Lee Hankins
macOS Sequoia (15.1.1)
When you say you can't use them, do you mean you can access the commands but nothing happens, or do you not see the commands at all.
If the first then you need to make sure you have the 'Accessories' library loaded - it does not load automatically.
If the latter then you need to re-install Archicad - don't start it.
Install the goodies.
Apply the latest update and then you can start Archicad.
