2008-07-21 11:40 PM
2008-07-22 12:35 AM
2008-07-22 03:06 AM
2008-07-22 04:47 AM
2008-07-22 09:45 AM
2008-07-22 06:13 PM
Rob wrote:You can copy/paste the 3D hidden line view. Just use the marquee tool in 2D mode.
I can portray it by marqui-ing it and putting into 3d/parallel projection/view from below but then if you want it in line then you have to go to internal engine and hidden line but then I can't copy it.
I'm thinking that I may then have to save out of this as 2dl.This has no advantage over copy/paste since you have to explode the drawing anyway (it's not possible to mirror drawings).
Since its modelled I suppose I could also invert and look down.This sounds like way too much trouble.
Further query though I believe it is possible to fix 3d cutting planes but I can't find the details.You can type in exact values for the 3d cutting planes. This makes it easy for horizontal cuts such as you need, even in the antiquated cutting planes dialog.
Any advise ?
2008-07-22 06:54 PM
Rob wrote:I am curious as to why you can't copy it. I have done quite often but not from the bottom looking up. I just tried it and no problem. You remembered that you have to select the single 2D marquee first right?
2008-07-22 11:29 PM
2008-07-25 08:30 PM
2008-07-25 09:49 PM
Miki wrote:Rob is working on a barrel vaulted ceiling so I assumed it was a condition that would look quite different from above and inappropriate for a ceiling plan (transparent or reflected).
I don't understand what you guys are complaining about since AC 10 (at least - I was not using 9 - kind of skipped that version) RCP are simple to do. Just keep in mind you never look up. You look down but from above the ceiling...
