The Master ID of
Hot
linked
Modules. It is an ID you can specify when you place a Hotlinked Module, or later when you select the Hotlinked Module and go to its Settings Dialog.
It can help differentiate the IDs of elements located in Hotlinked Modules from the IDs of elements located in your main Project File into which the Hotlinked Module is placed.
In Labels and Schedules, you can display the "Hotlink and Element ID", in which case the Element ID of elements located within the Hotlinked Module will be prefixed by the Hotlinked Module's Master ID.
