Change Layer Intersection Number for several layer combos in one swoop?
Mats_Knutsson
I've got a very faint memory it's possible to change layer attributes for many layer combinations in one swóop but either I have a bad memory or it's not possible. Is it me or Archicad?
/Mats
AC 25 SWE Full
4 REPLIES 4
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Mats,
Thank you for the question!
I guess this is what you're looking for?
https://helpcenter.graphisoft.com/user-guide/127879/ (Modify Layer’s Status in Multiple Layer Combinations)
https://helpcenter.graphisoft.com/user-guide/127898/#XREF_28748_Layer_Combinations
Let me know if this helps!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Mats_Knutsson
mnguyen wrote:
Hi Mats,
Best regards,
Minh
Ah thx Minh! Didn't know this feature moved to attribute manager. Why deleting the feature from the regular layers dialogue? An average user should not dabble with attribute manager but needs to change for example layer intersection number for his/her new layers. I would prefer to bring this feature back so it works also in the regular layer dialogue.
AC 25 SWE Full
Eduardo Rolon
It was never in Layer Manager, you can only select one Layer Combination there and it works like as always.
It was not possible until they added it to Attribute Manager.
Same as editing the ID# of everything in Attribute Manager.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Mats_Knutsson
Hmmm..must be my bad memory. Thanks.
AC 25 SWE Full
