2006-08-01 10:15 PM - last edited on 2023-05-26 03:06 PM by Rubia Torres
2006-08-01 11:26 PM
2006-08-02 12:35 AM
henrypootel wrote:That's what I was afraid of...Thanks for the info.
make a new view
2006-08-02 12:43 AM
James wrote:i stumbled on this too . . . but even though the 3D settings are greyed out, they
Stumped:
I've got elevation views. When I defined them, I had 'Transparency in Shading' ON in the 3D window settings. This is a mistake, and I would like to modify the views with the fix. Trouble is, when you go to the settings of the views, the 3D settings are grayed out.
So we have a 2D view with a 3D setting stuck to it, with no access to the 3D settings. (Not that the setting shouldn't be saved, but we should talk about whether SEs should be governed by 3D window settings. Another time.)
I never missed that redefine button until now! I thought I could trick it by going to the view settings with the 3D window in front, but no luck. Any suggestions?
2006-08-02 02:01 AM
~/archiben wrote:And you've tried this have you mate?James wrote:i stumbled on this too . . . but even though the 3D settings are greyed out, they
Stumped:
I never missed that redefine button until now! I thought I could trick it by going to the view settings with the 3D window in front, but no luck. Any suggestions?dochange if you use the 'get current window's settings' button . . .
so - if you go to the 3D window settings whilst in sect/elev window, then click on your view, it can be 'redefined' . . . although in a more roundabout way than we were used to in 9.
HTH
~/archiben
2006-08-02 02:38 AM
~/archiben wrote:I was so pleased to see this answer...but I can't make it go. I've tried these steps:
2006-08-02 02:40 AM
Link wrote:Oh, hey Link. I didn't see you, I was, ah, busy...
Link.
2006-08-02 03:28 AM
James wrote:...trying to find that ever-elusive last 20% of functionality again!Link wrote:Oh, hey Link. I didn't see you, I was, ah, busy...
Link.
2006-08-02 05:29 AM
2006-08-02 06:33 AM
henrypootel wrote:i saw the greyed-out 'Redefine Image Settings with Current' checkbox spring to life and figured that the view was being updated. you'd think by now i'd have learnt to check that it
The bug is that the method Ben describes should work, but it doesn't.
At the moment theonlyway to make it work, is to create a new view(which is really annoying if you use clone folders).
