Change a 3D setting of a 2D View?
Stumped:
I've got elevation views. When I defined them, I had 'Transparency in Shading' ON in the 3D window settings. This is a mistake, and I would like to modify the views with the fix. Trouble is, when you go to the settings of the views, the 3D settings are grayed out.
So we have a 2D view with a 3D setting stuck to it, with no access to the 3D settings. (Not that the setting shouldn't be saved, but we should talk about whether SEs should be governed by 3D window settings. Another time.)
I never missed that redefine button until now! I thought I could trick it by going to the view settings with the 3D window in front, but no luck. Any suggestions?
James Murray
Archicad 27 • Rill Architects • macOS • OnLand.info
10 REPLIES 10
__archiben
fixed in 966. well noticed laura!
http://archicad-talk.graphisoft.com/viewtopic.php?t=11911&highlight=
~/archiben
b e n _ f r o s t
