Change wall setting
epp
How can I change these settings that now are blocked?
thanks
I attach here a picture.
Botonis
Mentor
They are not "blocked" Just press the selection on the left that shows the sides of the wall. This way you wil activate the options.
epp:
See image as per Botonis's advice.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Zul Fahmy
You would need to click on the icon on the left to activate the surface override.
It will be highlighted in blue.
Fahmy
