Eduardo Rolon
Changing Origin of Vectorial 3D Hatch on Sect/ Elev
Is there a way to change/control the vectorial fill origin of a material on Elev and Sections? or are they tied to the project origin?
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
2 Replies 2
Eduardo
I think in AC10 you now use Design (in 9 was Edit) >Align 3D texture> Set origin / direction. It was peviously best done in 3D window rather than Section / Elevation window, not sure if that is still the case. This effects both the texture map origin and vectorial fills.
HTH
Eduardo Rolon
That did it, thanks. Though it still has to be done in the 3D window.
AC29 US/INT -> AC08
