‎2010-12-29
05:33 PM
‎2023-05-26
12:31 PM
Rubia Torres
‎2011-01-06 10:48 PM
‎2011-01-07 12:56 AM
‎2011-01-07 03:23 PM
Matthew wrote:I need to show the framing on top of what is supporting it, so it needs to be on the floor below
The typical approach would be to draw the second floor framing plan on the second floor.
Matthew wrote:Interesting this could work
Another way that might work for you is to make another floor framing story between the first and second floor at the same elevation as the second, but this will be a problem if you are using the elevator parts which don't play well with zero height stories.
‎2011-01-09 08:09 PM
Mo wrote:This actually works for me.
Ive adjust the cutting plane so it is not over head in the framing plan but not having much luck
‎2013-09-12 06:37 PM
‎2013-09-13 12:03 PM
‎2014-09-19 02:06 AM
‎2014-09-19 03:19 AM
‎2014-09-19 03:44 AM
