Denissss
Changing roof pitch changes roof type
Hi!
I dont get it. I drew a completely new simple gable roof. Then when I change roof pitch from tool palette
then Archicad changes my gable roof to hip roof. If I go into settings and change pitch from there it does not change my roof from gable to hip roof. What is going on here?
I am using AC28.
Archicad 28 Solo, Windows 11 Pro, Dell Precision 7560 Laptop (64GB RAM, i7-11850H, RTX A4000), Dual 27-inch Dell Monitors (2560x1440).
Setup info provided by author
1 Solution
David Maudlin
DenisUser:
This dialog should appear:
If it does not, look for the Enable All Informational Messages... menu command to turn these messages back on.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Go to post
David Maudlin
DenisUser:
David
Denissss
Yeah. Thanks. I think I at some point chose the wrong option and ticked do not show again. Enabling option was under work environment menus and you had to add it somewhere in the menu bar. File menu for example.
