Dontknow
Check drawing for external references
Hi All,
Is het possible to see if a ArchiCAD drawing has external references?
Greetings
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
4 Replies 4
Have a look at the Hotlink Manager to see if there are any hotlinks and the Drawing Manager to see if there are any external drawings have been placed.
Dontknow
Nothing under the Hotlink Manager and the Drawing Manager.
ArchiCAD 25.
Then I would say you don't have any external references.
If you do and Archicad can't find them you should get a warning message as you open the file.
Another place to check is the XREF Manager Dialog.
