My last experience dealing with Bentley (very frustrating by the way, ZERO tech support or assistance unless I owned a license, they debugged the file, gave it back to us, still garbage), we got multiple versions of the DGN and DWG exported from The City of Toronto (various versions, export options) and dealt with just about every tech person I could get in touch with, but basically we had no recourse to getting clean, sensible model output from Microstation, into ArchiCad. We even went as far back as AC7 to see if it could handle earlier DGN export any better. Nope. You had better believe we tried every form of import to AC as well. We had 4 people in our office working on this. The issue had to do with non-co-planar polygon edges, and tops of buildings not closing - which we tried to fix with a command in 3DS to no avail.
At that time (last year) I was in utter disbelief that (MS) would only export a DGN or a DWG - NOTHING else, I believe these were both versions 7 and 8. The quality of it's DWG was so bad we tried to open it in just about every program you could think of, Rhino, Revit, 3DS, Maya, Sketchup - not a single one of them could even open the file - only ADT, and the results saved out again, after extensive purging, simplification, audit, etc. gave total garbage in ArchiCad.
Every time I hear the word Microstation now I cringe.
Andy Thomson, M.Arch, OAA, MRAICDirector
Thomson Architecture, Inc.Instructor/Lecturer, Toronto Metropolitan University Faculty of Engineering & Architectural Science
AC26/iMacPro/MPB Silicon M2Pro
