I found an easier way to do what I needed, using a single wall, although it does require SEO.
Thanks for the great image Barry. Saved my tips & tricks folder.
May latest conundrum involves thickened walls returning to meet thinner walls with the same outer skins. I've crocked it with a wall end, but really need one that allows each skin to be stretched. I also see the wall end is not properly recognized as a Finish element by PSD, nor does it appear to pick up the skin priority from the composite.
The left shot shows what I want, although ideally the lines at the core should not be there since the fills are the same. On the right is the wall end that I used (top) and my fantasy wall end (bottom). I'm not sure if a wall end can be scripted to do that.
Regards, Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
